91 Force 90 HP L drive will not crank, it does turn over.
KenonP92
Any help would be appreciated as I can not get this motor to run. It ran good this past weekend but did have some issues with WOT but while attempting to sync the 3 carbs I found that the motor now will not start. The motor had been quick to start up and after riding for a while on the water and stopping it occasionally would take it a while to start back up. Any ideas as to what cold be going wrong here. Deff not a boat mechanic so any help is appreciated.
The Force power
Welcome to Iboats
Check out the sticky in this forum "timing & synchronizing Carb."
good luck
jerryjerry05
Yes read the posts on the top of the forum.
The first 4 are tips and procedures for the Force/Chrysler outboards.
LOT'S of good info there.
Since your a new mechanic.
The first steps in the diagnostic procedure is a compression and a spark check.
Do both and post the results.
If you don't know how? just ask.
U-tube has a lot of video's that you can access.
Add as much info as you can.
Like slow turning, backfiring, missing etc.
Fill out the signature and profile, you might be close to someone who can help???
