Re: 91 Force Impeller Change
See this thread.
http://forums.iboats.com/showthread.php?t=231685
Oh wait, you have a 70 hp don't you?
Pretty much the same except....
The shift rod separates on the starboard side, just above the midsection.
Mark the rod and coupler with a sharpie marker before you loosen it, it will save you lots of time adjusting it later.
The bolt head sizes may be a little different, and the pump is different, but the steps are the same.
