I bought a bass boat with a 1991 Johnson 60HP two weeks ago. It started, idled and ran just fine out of the marina and initially ran fine at full throttle. After 3 minutes it bucked violently, then recovered, then bucked again. It continued doing this the rest of the day, no matter the throttle setting. I had the power pack changed at the shop and it has a couple of problems that it didn't have previously.
1. It bucks and pops the steering wheel when I try to turn over the engine.
2. Once it fires up, it will only "idle" when the throttle is significantly advanced, not in the neutral position.
My shop is only open Tues-Thurs in the winter so that's why I'm asking now.
What would cause the popping on the steering wheel while cranking? When it fires up it's definitely in neutral.
Thanks!
Thanks!
