maineiac5586
Master Chief Petty Officer
- Feb 14, 2009
- 801
Working on a remote control 1991 johnson 9.9 electric start with ufi (POWERPACK under flywheel). I can't get it to turn off with key. I tried another remote control box same result. I disconnected the plug coming from under flywheel (black with yellow tracer) and ran a jumper from the pin in that one wire connector and when I put the other end of the jumper to ground it shut the motor off. I tried this a couple times with the same result. Not sure what that test signifies or where to go from here. Looking for help please and thank you
