Re: 91 johnson 90 wont run
I assume that you're saying that the engine starts okay BUT will not continue to run unless the primer solenoid red knob is turned to the manual flow position.
If so, put the primer solenoid back on its automatic position. Now, have someone constantly pump the fuel primer bulb, acting as a manual fuel pump. If this cures the problem, suspect a faulty fuel pump.
If it does not correct the problem, suspect clogged carburetors.
