I am having trouble with my 91 Model P50 overheating after several minutes at WOT. It runs fine at 3/4 and half but when it is a WOT the alarm goes off and it runs poorly until it sits a few minutes at idle. There is also a small puff of white smoke (steam?) when it is cooling off. I recently replaced the Impeller and I'm getting good flow through the pee hole. From other comments on this board it sounds like it could be a leaking head gasket. How much does a typical head gasket job cost for an expert to repair? How many hours would it take me to replace? I'm a novice mechanic but can usually mutter through moderate mechanical tasks.<br /><br />Thanks for all the great advice.<br /><br />Will
