Hello All!
This is my first post here, but let me say a quick thank you for the countless questions that have been answered by the experts in this forum for me over the last year or so!
Onto my issue: 91 Four Winns 190 Freedom with a 4.3 OMC Cobra. When first purchased boat it shifted relatively smoothly, but always idled very low and stumbled quite a bit, especially when cold. When taking the boat to have some work done on an unrelated issue, the mechanic said that this boat was idling way too low and that the ESA wasnt working. He changed the ESA out, dialed in the carb, sped up the idle, and off we went. (Presumably, the previous owner didnt understand the ESA and just adjusted the idle down to where the boat barely ran) The boat now stumbles when coming out of gear as I understand it should and shifts from F or R back to Neutral very smoothly. Going into gear from Neutral into either gear there is no grinding, and not much force is needed, but there is more of thud there was previously. I wouldnt go so far as to say that it "bangs" into gear, but there is definitely more of a "thud" then before.
So finally onto my question and I'm sorry if this has been covered before - when searching this I got some conflicting information. On my boat, should the ESA come into play when going from N into gear? As far as I can tell mine does not. And second, I realize it's tough to accurately assess my "thud" over the internet, but does this seem normal for this drive?
Thanks in advance!!
Tom
Thanks in advance!!
Tom
