91 yamaha 150 leak down test
jhosea1979
while doing a leak down on my 150 i could hear leakage coming out of the spark plug holes #1 would leak into #3 #3 into#5 #5 into #3 1,3,5 where around 35-55% does this mean its a leaking head gasket? if so would that cause a lost of 1000 rpms cly 2,4,6 were all around 12-20% with no leakage into the other cly any thoughts??
99yam40
Re: 91 yamaha 150 leak down test
If this is a 2 stroke, the most obvious way pressure will get to other cylindercombustion chambers would be head gasket.
If it was heading past piston and rings then it would have to get by the crankcase seals in between each crankcase also
jhosea1979
it is a two stroke would that cause such a lose in the rpms? what would cause a head gasket to just go bad it was running fine before?
99yam40
over heat and warped head, cracked head, or corrosion eating through head or block are my thoughts
