'92 25 hp Evenrude Lower Unit Removal
wullumh@aol.com
After removing 4 bolts & 1 nut holding on lower unit, I can shift the LU down an inch, but it catches on something. What am I missing?<br /><br />Thanks,<br />Wullum
Walker
Re: '92 25 hp Evenrude Lower Unit Removal
You are missing the shift linkage disconnect. I believ its behind the water intake screens in the lower unit. Its a plastic compression washer type deal. A manual would really be helpful to you.
rodbolt
yep takes 2 1/2 inch wrenches to uncouple. hold the bottom hex still and unscrew the top one. then slide the ferral nut up and remove the little black plastic "jesus" clip. when the clip flys off and gets lost you will understand the name.<br /> but first remove the water intake screens.
wullumh@aol.com
Originally posted by rodbolt:<br /> yep takes 2 1/2 inch wrenches to uncouple. hold the bottom hex still and unscrew the top one. then slide the ferral nut up and remove the little black plastic "jesus" clip. when the clip flys off and gets lost you will understand the name.<br /> but first remove the water intake screens.
Thanks! I will try that approach tomorrow!<br />Wullum
