'92-25 Merc primer question...
KIGuy52
My 25 Merc has a primer, rather than a choke. The diaphragm went bad so I ordered a primer/injector service kit. There are many small parts in this kit and I was wondering, would it be ok to just replace the diaphragm for now or should I go ahead replace all of the parts. The motor's on the boat, which is out at the dock, and I'm afraid<br />I'll drop something in the water if I try to change those small parts out there. I know the correct procedure would be to take the motor off and lug it into my garage, but I'm too old, weak and lazy for that.
KIGuy52
Re: '92-25 Merc primer question...
No, don't bother. All those other parts are a waste anyway, and they never work right and you'll probobly drop them in the water.
KIGuy52
Thanks. That's exactly what I wanted to hear.
ehenry
Talking to yourself and answering your questions, KIGuy52?
dakk1
KIGuy52<br /><br />Do as KIGuy52 suggests. You'll be happier.<br /><br />Dave..
KIGuy52
The primer works fine now. I'll change the tiny parts when I pull the boat up this fall.
