2 days now on and off and I still can't get this thing right. I've rebuilt carbs including floats and I've done the lync and sync twice. I've put the mixture screws back to where the manuel says to put them after removal.
The motor will start and run with the fast idle lever up on the remote control. As soon as the fast idle lever is pushed down it stalls. I look at this thing and know I'm close but need some direction. The idle timing thing is confusing me! Motor is in a tank of water for back-pressure.
Also, even with the fast idle lever up it's only reviving at about 2000rpm. It use to screem until I would push it down, seems at this point to be alot of play in the cable.
Wayne
Wayne
