juniorboy22
- Jun 22, 2011
- 7
I just wanted to know if the motor from a 1994 Johnson 40 hp engine fit on a 1992 evinrude lower unit?
The lower unit gearcase assy. have different PN's but the internals appear to be the same PN's. Did you mean a lower unit swap or a power head swap?
Check your year models closely as if they are as post it will not work. The dirfference is the crankshaft spline size and driveshaft. 1989-92 will interchange and 1993-03 will interchange..well i have a LU for the 92 evinrude and may be able to get a 94 johnson
