92 force 120 tilt & trim
smurf63
Does anyone know of a good source to get parts for the tilt and trim. I am trying to get on the water soon and have a problem with broken bolts and busted o-rings in the tilt actuater housing (I believe thats what it's called) five ss bolts and aluminum housing with a rod that raises in the middle of the housing? Thanks for any help or information..
RRitt
Re: 92 force 120 tilt & trim
hmm ...
seals should still be available from dealer. use 1/4 x 1.75" SS socket head bolts.
make sure to use x-long helicoils when fixing threads. The short ones can pull
out under full load.
