92 force 40hp wont start
Guido64
Have spark, cleaned carb twice. Replaced all fuel lines, fresh fuel, primer bulb pumps up. Will start fogged with fuel but not on its own
jerryjerry05
You using the primer? and fast idle?
Is the primer working right? key on, have someone push in the key as you pull the hose(from primer to float bowl) off the primer and see if fuel squirts
out. Put a rag under the area to catch the fuel.
