tu1aher1
- Jun 3, 2015
- 41
Hi All,
My Johnson 40 wont idle. It will run like a champ above idle. Carbs are clean. I have 120, 112 psi in the two cylinders. I already replaced the coil that the two spark plugs go into. This was really kicking my rear and so finally i took it to my local boat repair shop. The mechanic adjusted the timing and low idle mixture screws but could not figure it out then he discovered the low idle circuit coming from the stator was not working. He explained to me that there was a low speed(idle) circuit and a high speed circuit. I wanted to save some money and change it myself so he told me to take it home and remove the flywheel. I would see a serial number and that was the part that I needed to buy. So I dont know if I need to buy the whole assembly or just the power pack that has the serial number.
Please help if you can. That's why I'm asking what part of the assembly houses the low speed(idle) circuit.
Thank you guys
Thank you guys
