'92 Johnson 60hp, blown motor, need help!
jaykno
Hello everyone!
I recently threw a rod on my 1992 Johnson 60hp 2 stroke 3 cyl. I'm trying to determine my options for repair/replacement.
I know very little about boats and outboards, but am very mechanically inclined otherwise.
The boat was given to me by my grandfather, and it has been sitting up for years (5+).
Me and a buddy put a lot of time and money into getting it ready for the water, and it threw a rod on our second day on the water.
Rebuilt carbs, new plugs, new thermostat. Tested the VRO pump and confirmed it was oiling to spec.
I've been trying to find a used power head or even a replacement johnson 60hp, but I haven't had much luck. I'm not sure what my options are at this point.
The motor is on a 1992 Stratos 254, 15.5 ft bass boat. I know it says not to put anything bigger than a 90hp.
Any advice is much appreciated! Since this is a family boat, and I'm new to boating, I was really hoping I could get it up and running without breaking the bank. I was going to use this boat to learn the "ropes" and possibly upgrade to a bigger boat next year. I'm not interested in fishing, just cruising around with friends.
jaykno
I thought it was rated for 90, but I just double checked and it's rated for up to 70hp.
jaykno
I found a used motor, 1994 johnson 60hp. They guy is willing to sell the outboard, minus the lower unit and tilt/trim for $800. Is that a fair price?
flyingscott
Does it run? What is.compression? If all those check.out it might be a good deal.
Your location ?----If it is a guaranteed good powerhead it sounds cheaper than just the parts you need to repair yours.---Listen to it run or perhaps a compression test before handing over the cash.
jaykno
The guy ended up selling it to someone else. :(
I'm located in Baton Rouge, LA.
If you guys know of any motors or powerheads available, please let me know!
