Went to trim down today & it wouldn't from helm or the engine trim switch either one. It will however trim up from either. Can feel relay clicking when using the down position & don't feel anything when trimming up. I'm assuming this realy is for the down position only.It does have 2 relays & I assume one is up & the other(lower one) is down. How can I check this ??? It had worked perfectly as usual until I went to trim it down. I had to use the manual release to put the motor toter on. Any suggestions ???
