I have a major problem with this boat. It idles fine but when I step on the throttle all the way it has very little power about equal to 1/4 throttle. It will come on pretty good if I press in the choke on the key in a fluttering motion.When I let go it will die down again. If the fuel pump is bad would it run like this? I have cleaned both carbs in a carb cleaning tank, changed plugs,checked compression,cleaned gas filter on fuel pump. The carbs have been cleaned three times. Pulling out all jets and blowing air through the carb orfices. I have checked all gas lines,they look good. No water in gas,The inside of the pump looked ok? plugs look ok.Im baffeled.
