92 Mercury 150 Starter Problems
bucklt
I have a 1992 Mercury black max 150 that has been hard to start. It doesn't seem like the starter is spinning the motor fast enough. Today I turned the key and the starter didn't even engage on the first 2 tries. On the third try it engaged but would barely turn the motor over. I had just charged the battery and it had a little better than 12 volts. However, I thought maybe the battery wasn't holding under a load and so I tried another battery with the same result. I cleaned all the electrical connections on the starter and solenoid but it was still weak turning over. I measured the voltage from the positive on the starter to the ground on the starter (ground that goes to the block) with the starter engaged. The highest voltage I got was 7 volts. I checked the voltage on the input side (battery cable side) of the solenoid without the starter engaged and it had 12 volts, but I haven't checked it with the starter engaged yet. So, I guess I have 3 questions...<br /> 1) Could the solenoid not let enough power get to the starter?<br /><br />2) Are there any checks I can perform to be sure it's the starter before I drop a few hundred dollars on one?<br /><br />3) If it is the starter then would you recommend buying a new one or trying a starter kit? (I've seen these kits advertised for about $30 and it appears to contain new brushes etc...; not sure how difficult they are to install)<br /><br />Thanks in advance for any recommendations!
Barnacle_Bill
Re: 92 Mercury 150 Starter Problems
Have you tried bypassing the solenoid? If it turns out to be the starter, most automotive electric shops can rebuild it for you. We have one in Va Beach that does excellent work.
LurkingBear
I think the 7 Volts is the problem. I don't think a 12 Volt starter will spin very fast with 7 Volts.<br /><br />With the starter engaged, measure the different points in the circuit to find out where you are losing the other 5 Volts.<br /><br />You've probably got a bad connection somewhere that's causing the voltage drop.<br /><br />You have to look for the voltage drop with the starter engaged. You need the current to the starter for the problem to show up.
bucklt
I cleaned all the grounds up and that seems to have fixed the problem. I guess it wasn't getting a good ground and that prevented it from getting the voltage it needed. Thanks for the replies.
Ben Konopacky
Have the batt.charged and checked with full amp draw of starter rating and record the the voltage drop, if you don't have at least 9.2 vdc get a new batt.the 12 v standing realy mean much w/o a load . good luck
