92 OMC Cobra 5.8L low rpm after 20 min cruising
cheers731
Hi folks,
Need some help troubleshooting on this repeating problem. It's a 92 OMC Cobra 5.8L engine, easy start up on cold engine and runs well at WOT after warm up and cruising over around 15-20 min. Then the rpm will fall gradually to 1500 and if I push more gas, it will stall. Then it gets worse, I can only run it at idle speed. At this point, I can smell some unburnt gas at exhaust. If I let the boat sit overnight, it will run fine for about 15-20 min. I had plugs, wires and fuel pump replaced a year ago and no improvement. Is the ignition coil get overheated or something else. I appreciate any suggestion or advice to get this problem resolved.
Thanks,
Frank
Re: 92 OMC Cobra 5.8L low rpm after 20 min cruising
Hi folks,
Thanks,
Frank
Ayuh,.... Sounds like a Fuel Delivery Issue,...
Start at the Tank vent, 'n work yer way to the Carb,... Everything is Suspect,...
cheers731
Thanks for the reply.
I checked the entire system last year when it first started. New water separator, fuel pump and checked anti-siphen valve and make sure it deliver without restriction. The funny thing is it happens repeatedly after 20 min or so of running. I read more on the forum, could it be the timing off? I have replaced cap, rotor, wires and plugs but not done other parts of tune-up, such as condenser and contact set. They are probably 6 years old.
Thanks again,
Frank
Thanks again,
Frank
Ayuh,... The Points, should be changed Every Spring,....
tfitch03
I had a similar problem in an airplane. We could fly for a while then the engine would sputter and die. Deadstick landing, fill up with gas (hissing noise when we opened gas cap), engine started back up, ran great, then sputtered and died. After a formal investigation we found that a mud dauber had clogged the vent tube. As fuel drained out it would create more and more suction eventually effecting engine performance and then total fuel starvation.
Like Bond-O mentioned, everything is suspect but I would take a close look at the tank vent.
cheers731
Many thanks for all the advice, really really appreciated it.
Frank
cheers731
Ok, I have eliminated a couple possibilities and will trace down the vent hose to make sure it performs correctly.
Here is my question: how do I know if I have points system? Does points or condenser gets overheated if timing is off?
Again, your input is highly appreciated.
Frank
bonzoscott
I believe all OMC went CDI ignition '90 and some maybe '91. And a little crazy - this is what you could do. Do you know where the vent is? Should be close to fill. Drill a 3/8 hole through a tennis ball. Place it on the fill. Stick your compressed air nozzle in the outer hole and give it 125 psi. It should be whistling outta your vent.
cheers731
Great idea, will give it a try.
Can't say enough thanks for the helpful ideas.
Frank
jerryjerry05
Blowing compressed air into a gas tank isin't good idea.Something about static electricity and blowin up???
Most newer boats have a vent with a filter in it?
Post a pic of yours?
Unhook the vent line and blow through it.You'll be able to tell if it's clogged?
After it runs for a while, touch the coil and see how hot it gets.
It should be warm but not so hot you can't touch it.
You should have electronic ignition.
Ayuh,... That's abit Excessive, 'n could split the tank, Wide Open,....
bonzoscott
Thanks for the advise jerryjerry05, and Bond-O. I used that method to drain 20 gal of 6 year old fuel from a project. Won't do it again!
Mattrick2oo3
This is the exact same problem I am having! Did you ever figure out what was wrong with it?
Thanks,
-Matt
Maclin
The simplest thing to try is loosen the main fill cap, let it grab air until it stops hissing, then leave it less than full tight, start 'er back up and drive on.
Maclin
Oops, left this part out... If that works the FIX THE VENT AS SOON AS YOU CAN :)
Mattrick2oo3
Thanks,
Can you tell me where the vent is located on the tank? I didn't see one when I removed the anti siphon valve to inspect it.
Mattrick2oo3
Nevermind, found it... The bottom screen looks a little plugged up and does this position (vent holes facing downward) make it easier for water to be pulled into the fuel system?
MikDee
Banned
Can't see the Pix! Use the little camera icon for pix off your computer. Use the clipboard for photobucket..
