Hi all,
One of my 250's is very difficult to start. The only way I seem to be able to start is to follow the "Manual Fuel Enrichment Valve Starting Procedure," which calls for turning the valve on, priming the bulb 6 times, then starting.
Seems to do the trick every time. When I rebuilt the carbs, I blew air and cleaned out the passageway that each "electric" valve is in.
Any suggestions? Once running, all else is ok. I searched the forums and could not find a similar problem.
Thanks!
Kevin
Thanks!
Kevin
