My 3.0l won't start.
Hello,
My 93 Mercruiser 3.0L is cranking great but will not turn over. Hasn’t been started for 8 months, replaced the starter plugs and cleaned out the carb(waiting on rebuild kit). I have spark and fuel at least getting to the carb. I checked my compression last night, keep in mind it has not been ran and it’s still pretty chilly here. 1-3 40 psi and 4 had around 60 psi... 1-3 spark plugs are brand new but covered in oily burnup. Are you saying sea foam could stop that extra oil from getting in there?
Re: what should compression be on a 3.0L?
It sounds like it is a bit high unless the gauge is off. Do you have someone elses gauge to try? Only thing I've heard that would cause a high reading, is allot of carbon build up. Normally, not an issue on 4 strokes. Were the plugs black? How has you engine oil consumption been? I use seafoam sprayed into carb, to get rid of it on my 2 strokes.
Hello,
