I got my boat out of winter storage this past weekend and tried to start it with the muffs on before I went to the lake. <br /><br />The first couple times I turned it over it just clicked a bit. I checked the battery connections and tried it again. This time the starter engaged and wouldn't stop, until I disconnected the battery. After some troubleshooting I disconnected the small wires from the solenoid and when I connected the baterry the starter would still run. <br /><br />At this point I figured the solenoid had to be shot so I took it off. Just to prove to myself that the solenoid was making a constant connection I tried to arc it across the battery (I know, probably not too safe). Anyway, nothing happenend. So I put it all back together and it worked fine the rest of the weekend. Probably started it a dozen more times.<br /><br />My question is, do you think the solenoid was stuck and fixed itself when I took it off or did I unknowingly do something else? And should I just replace the solenoid just to be safe?<br /><br />Thanks for any help.<br /><br />Joe
