93 60hp evinrude impeller
dturn24
I have a 93 Evinrude 60hp, water is not coming out of the top hole so i figured it was the impeller so I started to take the lower gear case off, got all the bolts out and the lower section drops down about an inch and stops. What am I missing to get the lower case off?
Zeeter
Re: 93 60hp evinrude impeller
Unhook the gear shift lever below the bottom carburetor. Good luck now that you have it this far.
dturn24
I already gave up for the night but I'll try that tomorrow thanks Zeeter
tashasdaddy
remove starter air silencer so you can see what you are doing.
