I've got a '93 Johnson 88 spl. Tach started to work erratically, so I replaced the rectifier. This is an unregulated rectifier. Tach now works, but doesn't charge the battery.<br /><br />Here is what I've checked:<br /><br />1) Followed Joe Reeves small rectifier check - I've got a reading going one way, none the other for all wire combinations (checking resistance against ground, then against red wire). This indicates rectifier is good.<br /><br />2) DC voltage across battery = 12.5 volts. DC voltage at idle across battery = 12.5 volts. DC voltage at 2500 rpm across battery = 12.5 volts.<br /><br />3) Checking the charge coil (from my Seloc manual) - the 6 amp stator should have 500-610 ohms across leads from stator to powerpack. I'm at 565 ohms. <br /><br />4) Checking continuity from leads (see 3) to ground, should be none. Have none.<br /><br />5) From another post on here "check stator coils for gooey discharge" - found none.<br /><br />6) From another post on here "check stator ohms on 2 yellow leads to rectifier - should be 0.17 +/- 0.5" I'm at 0.17 ohms.<br /><br />7) From another post on here "check stator output with peak reading meter, should be 18-20 VAC across 2 yellow wires to rectifier" I don't have a peak reading meter, I used my multimeter on VAC, and two different multimeters read 35 VAC.<br /><br />So... is it possible that the rectifier is bad, even though the tach works, it is brand new, and it passes Joe Reeves' test? What next?<br /><br />Tim
