'93 dancer prop?
Ranchhand
I recently purchased a 93 230 sundancer with a 305 merc. Does anyone have this or a similar combo that has found the right prop. Any advice would be appreciated.
Thanks Dave
Crownie2
Re: '93 dancer prop?
What HP, which drive, and what drive ratio?
Bob
Ranchhand
Oh sorry
Um 220, Alpha one and not sure. Where would I go about finding drive ratio. I'll try to remember to look tomorrow.
Thanks Dave
Crownie2
Port side of the drive, about 3 inches down from the top.
Crownie2
Those may very well be the standard ratios but some boat manufacturers use optional ratios and I was trying to eliminate that possibility...
If we use the 1.62 ratio, the Merc Prop Selector shows 19" in a three blade. You may have to go to a 18" in a four blade. This is a starting point and guideline, only.
Good Luck!
Bob
