chopperguy
- Jun 18, 2011
- 66
So, after replacing almost all ignition components she was running great until Sunday. During a 12 mile trip home on the ICW at 4500 RPM, she suddenly droped RPMs by 500. I limped the thing home. She was shuttering every so often like a. Miss fire. Got her out of the water. Check the plugs. The left bank plugs were wet and the top plug had a bent electrode, see photo. Compression check was 90 psi on both cylinders. Same as when I bought the boat. Anyone ever see this happen? I am not sure how to proceed. Should I pull the head and inspect the piston? Compression is good and everything seems to be moving properly.
