My 1993 Evinrude Intruder 150 has been having an intermittent problem
. The motor will shut down at acceleration from idle and then at idle, and then not start at all. This happens especially after short trips and cooling down after some fishing. The engine does not sputter to a stop but just flat quits. After a few hours or more, the engine will run without a problem. <br />Following service has been done by authorized Evinrude repair shop: 1) New VRO pump 2) New optical fuel line sensor. 3) New primer bulb and fuel lines. 4) New spark plugs 5) compression & spark check - OK. Problem is intermittent so very difficult to duplicate at repair shop. I mix my oil manually. Some days I can run the boat all day only to have problem occur at the end of the day.<br />Something is happening in the engine that is telling it to stop firing. Can anyone please assist?
Thank you.
