glen whitley
- Jan 25, 2004
- 8
I have a 93 evinrude 150 with ois 2000 ignition<br />it was runing bad so I check fireing it had fire on port side so I disconnet shift interrupter switch still no fire,so check the stator tested ok, battery good,so I put a new pack on it ran great for about two hours then the pack went bad.<br />it had melted on the back just like the one I took off. I look at the regulator/rectifier it had somthing coming out of it . Do you think reg/rec. could be my problem any sugg. <br /> THANKS
