Re: 93 Force 90hp, trim won't go down
you can't be sure because you swapped wires instead of relays (or entire relay connector blocks). However, it is probably the relay. Relays are dirt cheap. They are a generic part used on 12v motors, stereos, alarms, and lighting. You can find them for $2-$10 each at local auto stereo shops, ebay,amazon. Look for the ones with glue around the base. Most, but not all, of the cheap ones do not have the glue around base and the plastic housing can pop open. The glue is meant to secure housing but actually helps keep out moisture in a marine application.
