dbharrison
- May 24, 2007
- 3
Hello everyone.
I have a '93 Johnson Tracker "Nitro" 150 model TJ150GLETG on a '93 19 ft Pro Line Sportsman.
The last couple of times I've had it in the water, it has stalled when I give
it throttle of more than "barely above idle". I can not get it to clear itself
to see if it will run at WOT. When it stalls, I can prime the bulb and restart
and it runs ok again. Primer bulb will pump tight in 2-3 pumps but goes
very soft as soon as I begin to run it again. I have to idle through a long
channel to get out of the marina to the bay via a no-wake zone and it will
get out there ok. Once it stalls, it doesn't even want to idle smoothly
unless I repump the bulb. To get it back through the no-wake zone to the dock, I have to repeatedly repump the bulb just to keep it at an idle. I have read several posts that offer advice to try using the choke button on the key to keep it running instead of the primer bulb but unfortunately, I didn't think to try to that when I was on the water. Also, it seems to have a lot more white smoke than it used to or should, even after it is warmed up. It starts and runs fine on the trailer using the Mickey Mouse ears, but that is only at idle under no load. I have checked all of the hoses, connections, fuel filters, and replaced primer bulb. I have a pressure gauge that I am going to test the pump with. After reading other postings, I am also going to check the anti-siphon valve which I'm assuming is in the pick-up stem inside the tank?
Here is the root of my question: My brother was conducting routine service and filling the fluids and accidentally bought a quart of 4-stroke oil instead of 2-stroke and put it in the reservior along with some 2-stroke oil. The ratio that went in the tank was 1:3. When I noticed the empty container the next day, I drained the tank and lines and replaced it all with 2-stroke and all seems well now. I did not notice any problems with performance that day. Is it possible that the mix of 4-stroke and 2-stroke could have damaged by VRO pump on the fuel side which is now causing my stalling problems? What other side-effects and problems would that have caused?
I went ahead and ordered a new VRO pump to see if that is the problem.
Any thoughts are appreciated.
Thanks,
Boone
Thanks,
Boone
