BOAT for the love of it?
- Aug 13, 2023
- 11
Not sure where to start but I have gotten myself into a jam helping my son with a '93 Johnson on his boat with all sorts of problems. It's a 40hp and I have worked through a dozen or so issues to figure out the lower unit wasn't performing right. When I took it apart to determine if I had broken gear or worn gear, I found a worn dog clutch but not enough I would say it's the problem. I think in the end it might have just been low gear oil. But here is the weird part, one of the parts that came out was a one-half metal ball from I cannot tell you. It came out as I was pulling out the dog clutch and the backward gear.... I mean I took this lower unit completely apart. SO, I put it all back together except for the metal ball. Still didn't shift well, so my son bought a lower unit on Ebay (which was completely useless, a story for another time). But it had new gears and when I took it apart, there was no metal ball. I took the gears, prop shaft, etc and moved them into my casing. BUT I lost track of what gear I was in and the length of the shift rod. I had a medical issue come up and I came back to this project after several months. Anyway, I thought I worked my way through my issues..selected a gear, measured for the shift rod (found the standard 21 23/32 in neutral...I dialed it all in. I go to turn the engine over (after 2 years) and it comes on after the 2 key turn...wonderful. I am a hero, not so fast and here is where I need the vast wisdom of this collective body cause I am about to blow this engine up. Neutral spins at a pretty good clip vs no spin. Forward no problem dialed in and moves. Reverse, no, it only goes forward. I cannot get the dog clutch to move while in the casing but works fine outside of the casing. The ebay casing is smaller and the guy drilled holes in it for only god knows. And he put the dog clutch in backwards. I thought because the dog clutch was in backwards was the key...but now that it is corrected, I have no clue. There is room in the casing and the parts are exactly the same as the old one...except there was that metal ball. So, I am open to some questions and some suggestions before I rip this thing down for what is going to be the 12th or 13th time.
In my shift dog shaft, there is 3 bb size bearings and then a spring. I was considering taking a bb out. Because this shifting is so tight, I am not sure the shift rod is able to pull and push it.
