So I have a 1.84 gear ratio outdrive with my 3.0l merc engine. The boat is a 20' cuddy. I am getting about 4200 RPM at WOT, while running about 33-35 mph (according to the speedometer) The outdrive has a hydrofoil on it as well, and has no problem getting up on plane.
I have read that WOT should be around 4400-4800 for this engine. Do these numbers sound close to what they should be or should I try a different prop to make up for the different ratio? The boat cruised at about 28 mph or so while running 3700-3800 rpms.
It currently has a 14.5x19 prop on it right now.
