Is there a way to adjust the neutral safety? I have to hold the shifter in the exact spot for the ignition switch to engage, and if I try to shift into the fast idle the ignition won't engage. Its really tough to get the engine to start without giving it any throttle. There has been a couple times the engine would crank while in the fast throttle, but for the most part it will not.
