'93 Mercrusier 4.3 cutting out at WOT + trim
MooMar57
I am experiencing significant cut out at WOT when trimming up. As if trim is sucking electrical power from engine. I can write a book about what I don't know about this engine.<br /><br />Any ideas?
Rickles
Re: '93 Mercrusier 4.3 cutting out at WOT + trim
You're into the factory equipt rev. limiter.It won't let you over rev the engine.Either don't trim up as far or drop your prop size down.Also check the trim limit sw.adjustment.
Tufan
I'd check the wires of the control box.
