93 Mercury 75 Tilt & Trim Problem
crwtuna
In the process of getting my boat ready for some fishing I noticed that the trim motor would run when the switch was deperessed but the motor would not raise or lower. The motor was all the way down at this point so I turned the relief screw out 3 turns CC per the instuctions in the owners manual. I could only manually move the motor to the vertical position before encountering resistance.<br /><br />Any ideas? Thanks in advance for you input.
