Been reading the posts on here for a month now. Great information great users. Here is my problem. On the top cylinder I have intermittent spark. Spark there when engine cranks.. Disappears when the engine is running.
What I have done so far.
Switched top coil to middle plug.switched terminals on the switch box. Get spark from coil constant. Ruled out coil. Stator appears to be replaced. (engine runs fine and starts up instantly on 2 cylinders). disconnected wire for ignition/rev limiter no change.
Is it the trigger/switch ??? I'm at wits end at this point. Any help is appreciated .
Thanks
Thanks
