94 150 EFI-Gas Line size?
mxzer29
Hi everyone,
Can any body tell me the gas line size(width) I need to have? Inboard tank. Switched boats left the gas line on the old boat.
The line on the boat now is from a 90 HP Johnson, think it would be fine??
Thanks
Pat
Chris1956
Re: 94 150 EFI-Gas Line size?
You need a 3/8" fuel line. Any brand will do. You might consider permanent attachment to motor and fuel tank, versus the quick disconnect fittings. Quick disconnect fitings tend to impeed fuel flow.
mxzer29
Thanks Chris, I will check when i get home..Now if I need new gas line, i can get it at a auto store..Can i use the primier bulb from the old line??or do i need a new one.
blazer81.6
go ahead and replace it. You can buy primer valve and fuel line at Walmart for under 15.00. Its worth replacing.
