94 150 faststrike
poorboy123
runs good while constantly pumping primer bulb but gives no oil alarm. any ideas???????????
tashasdaddy
Re: 94 150 faststrike
air leak fuel line, failing full pump, clogged vent line to fuel tank, dirty filter, clogged carb jets.
poorboy123
wil falling pressure to the vro\fuel pump cause the no oil alarm?
poorboy123
ran fine for first 2 hrs. then started surging like it was running out of gas. as i stated before runs as long as you keep bulb primed but gives no oil alarm.i will change filter and gas line. iwant to mix my own oil and gas. can i just unhook the wires to the pump and cover inlet?
jonesg
if the fuel line is seeping fuel it can draw more oil (cycle oil pump faster) but you usually know because it fouls the plugs and smokes then idles rough but the alarm will not sound.
Use a flashlight, pump the bulb up and look at the fuel lines under the engine hood, you might find fuel running down the lines or leaking from a connection.
Use your nose, it can lead you to a leak.
examine spark plugs , they might be oil fouled which leads you back to fuel leak.
