Re: 94 200 Ev. headgaskets
I'll have to look when I get home about the manufacturer. The gaskets look pretty good, with a thin blue line of sealer where needed, and one sticky side. .020 cleaned up the bad cylinder, and yes, I am replacing all of them. I had one carb needle stick closed for some reason, which caused the hot cylinder by the time I was able to diagnose what was wrong. I got the needle free-did not see any reason for the occurance. The engine ran fine for a day, then started not idling properly. Comprssion test showed me bad news. 5 @ 110psi, 1 @ 70psi.(NOT GOOD!)I've got all 6 new pistons/rings installed, getting ready to put the heads on. That's when I noticed the difference in the water passage cutouts. It looks like the new gaskets limit flow through the heads to only from the bottom to the top, instead of circulating past the head gasket towards the block. What do you think?
