Re: 94' 40hp Force -Using "ears" to flush your engine
It may be hard to find muffs that will fit the water intake. Look for ones with sqaure cups on it,as the round ones wont werk (been there, done that).<br />I used to use a trash can (still do sometimes), with a thru-hull fitting in the bottom of it to drain it when done----It werked super.<br />The two hole in the leg should emitt a "sputter".<br />There is no telltale on these motors.<br />But after the thermostat opens up (about 30seconds to a minute), it should sputter out of those two holes as if you told it a joke with a mouthfull of water.<br />Consider mounting an aftermarket temp gauge on it. I used a digital outdoor/indoor thermometer I bought a Radio Shack for 10 bukz. And I glued the probe to the block using JBWeld. I have yet to change the button battery in it, but it's hard to read in sunlight. Of course, they make a gauge that pluggs in, but they are hard to find, and an auto gauge reads too slow to be of any use. If you decide not to mount one, just keep an eye on those two holes.<br />Being a newbie to boating, you may want instructions on checking the lower unit;<br />
LOWER UNITS 101 <br />With frequent decarbing,and and attention to all maintainence items, you should get lots of fun out of that engine.<br />And welcome to iboats
