Hello. I"ve been posting in my other thread about this motor regarding low comp, but I've also been trying to figure out what is up with the lower unit. I'm not getting much help on it in the other thread, so figured I'd start a new one just for this. Here is my problem, and what it's doing.
First off, this is a project motor, so it's not on a boat, and I can't get it on a boat since I don't current'y even have a console in my boat.
I can't get it to change gears at all manually, with the controls disconnected. So, if I connect the controls to it, I can get it into forward, although a bit "clumsily." I can't get it into reverse at all. I can get the controls to go into reverse, but the engine isn't in reverse, since I can spin the propshaft by hand. If I get the controls into reverse and then (leaving it that way) disconnect the control cable, the motor will instantly pop back into the neutral position. I tried turning the prop shaft by hand to get it to line up, nothing doing. Also tried that with the flywheel just in case, same result. If I watch the shift rod under the carbs as I shift it, I can see the rod move down when it goes into forward, but when I try to put it in reverse, the rod actually moves towards the front of the motor, front to back, instead of up or down. I don't know how it is supposed to move, but if forward is down, I'd think reverse would be up. It almost seems like the rod is flexing or bending out instead of shifting into reverse. I can't really explain it much more than that.
Does anyone have any ideas on what is going on with it? I can tell someone has been working on this engine before I got it, so I don't know what they were doing, what they did, or how knowledgable they were when doing it. I am open to suggestions at this point, even if it means pulling the LU to check it out. I've never done it before, but with the help from members on here and from doing some reading on it, it doesn't sound terribly complicated.
If you think it's something else, please let me know, any and all suggestions are appreciated.
Last thing, is I pulled the lower unit drain screw to check the fluid. I don't know if this stuff is just terribly old or what, but it's nothing close to the color of the oil I use in my other outboard. It could just be seriously old and dirty, but let me know what you think. Attached are 2 pics, one if of the oil that came out of this thing (no, not all of it, just some), the other is the kind of oil I normally use, it's Pennzoil.
The pics should be clickable to view them in full size.
