94 Evinrude - extra wires
dnadorozny
I recently purchased a 1994 Evinrude 20 HP which does not come with electric start. There were to wires that come out of the front of the motor, which are bound and about 2 feet long. I put a meter on them when the motor was running and got a small charge being produced. Is it safe to assume this motor has a small alternator built into it? I have only seen alternators in the past on motors that have electric start. Thanks!
clanton
Re: 94 Evinrude - extra wires
It is an AC lighting stator, different part number then same engine with charging system. Trace the wires back to engine, may find 3 wires if voltage not over 30 volts AC between the 3 wires, you might be able to connect a 4 wire rectifier and have low amp DC.
