94 force 40hp no spark
Race74m
I picked up this boat with a non running engine which has me completely stumped, can’t find a good schematic for the wiring, things that have been replaced the stator the trigger the Cdi box ignition switch and checked all the grounds and cleaned and reinstalled grounds, have a inline spark tester on and still no spark checked magnets when replacing stator and all were good shape and any help would be appreciated. Not sure but when you turn key to on before turning over engine should I have dc power to one side of the coil, and yes I have unplugged black wire with yellow stripe no spark unplugged both yellow wires from stator and no spark
jerryjerry05
Kill switch hooked up? Two different kill lanyards were used.
Pics of the shifter/ control showing the key switch.
Even a new stator/ pack can be bad??
outboardigniton.com has test procedures for your motor.
Your ignition components are 99% Mercury.
