hartofdixie
- Apr 4, 2012
- 8
I hope someone can help me on this one, the issue is that my engine will run with the fast idle lever pulled up but when it is brought down the motor cuts off, I reviewed the carb-sync sticky post but I am not sure if that would apply to the 50hp w/ only 1 carb, the engine has worked fine in the past but recently I replaced the inline fuel filter because there was a leak causing the engine to cut off. I also turned the screw with the spring on it on the carb clockwise to see if it would speed the idle up but it didnt seem to do anything so I turned the screw back to where it was originally, does anyone have any advice on how to speed up the idle?, any help would be greatly appreciated.
