94 four winns fling ?s
vortecmax4x4
:confused::confused::confused:this is my first post and it regards my first boat. i have a 94 four winns fling with 115 hp 2 stroke when i turn the key over i get a constant beep.and the boat has not been in the water in a while but has been kept inside. i have taken it out once since i bought it. i am just wondering what this means i have no manual or guide for this any suggestions will help........and is there any way i can attach my garden hose to it to keep from driving 15 mins to the water to work on it:confused::confused::confused:
180shabah
Re: 94 four winns fling ?s
First, welcome to iboats.
second, your fling is a jet drive, IIRC, so you will get a better response from the PWC crowd. There are some who frequent both forums, but the I/O - inboard boats are mostly "car" based engine, while the jets are not.
Ayuh,... Welcome Aboard,...
You'll find your Answers over in the Jetski Forum,....
This is the I/O Forum.....
Maybe a moderator will move it for you, or you can repost over there....
njlarry
I have a Boston Whaler 15' Rage which has the same jet drive. A constant warning horn means an overheat. A repeating horn means a lack of oil from the VRO tank/pump. A handheld IR temp guage is a real help with these drives. I would take apart and flush out every inch of the cooling system also make sure there is already a strainer in the intake hose off the back plate of the drive as they often suck up sand and clog the cooling system.
njlarry
Forgot the second half of your post;
They made an adaptor that connected a garden hose to the outside of the intake where the housing opens to clear out weeds etc. TurboJet sells these and other jet parts. You could also rig up a garden hose to the water intake inside the engine compartment.
Good luck with it. Outside of cooling system quirks the drives work well.
