hi all,
I just purchased a 94 four wins horizon 180. the boat is in great condition when it starts. I am having issues starting the motor, the motor doesn't even sound like it is turning over. I turn the key and nothing happens, I almost think that it is not reading neutral which is causing it not to start. I wiggle the throttle for a long time and eventual (at random times) it will crank the motor over. Like i said I think that the motor is reading that it is in gear so it will not try to crank it over. Is this a throttle issue or maybe a cable issue. I took it to the shop and they replaced a relay in the throttle that was failing, but that did not solve the problem. Any help would be great.
