I just bought a 1994 Seadoo gtx. It has the rotax motor. I don't know much about these things as I have never owned a PWC. The craft had not been run in about 2 years. I started it yesterday and it fired right up after I changed the spark plugs. What things should I do to before I put it on the water? What should I lube, tighten ect... It has oil in it that is at least a couple years old, should I drain it and put new stuff in? If so what kind of oil? I did pull the old gas out. Other then those minor things I have no idea what else should be done. Any help in this would be greatly appreciated!
Thank you
Thank you
