94 mariner 200 hp throttle wiring
Dboii
Hey what's up guys I ran into a little bit of trouble hopefully one of you guys can chime in. I connected the trim up and down wires to my engine wiring harness from the throttle but there are 3 more wires which I don't know where they go. The wires are two yellow and red wires coming from the throttle and also a red and purple. I was wondering if I had to splice those wires into my engine wiring harness then connect to ignition switch? Here's some pictures of what I'm talking about
Dukedog
anything red, with or without a tracer is a "constant 12v hot".. you have to have one of these going to all tnt switches.. tha two yellow/blacks from tha control box make up this way.. one will make up to tha one yellow/red from tha switch and tha other will make up on tha yellow/red in tha harness.. those go to tha neut. safety switch.. tha switch purple makes to a purple in tha harness.. that is a "switched 12v hot" that comes hot with key in on position.....
