I cleaned and rebuilt the carbs a couple of weeks ago. New plugs, new oil, new gas. Everything was fine for about 5 hours. Now, it's stalling when I put it in gear. (runs like a champ in neutral).
I looked in the plastic gas tank and saw a few floating rust particles. Do you think my carb is clogged? If so, should I rebuild it again, or can I get away with some type of marine grade carb-cleaner/spray? (I will be replacing the gas tank & fuel line asap). Thanks in advance for any help.
